0 Members and 1 Guest are viewing this topic. Read 10344 times.
I have had good luck using Nichicon Muse KZ series bypassed by Reliable Capacitor RTs in the high current supply....Tried some of the fancy Elnas and Black Gates and liked the Muse better in our designs....Best part is they are quite a bit less money and felt they matched well with the Rel bypass caps....
hehehe, yes line filters... i'm looking at getting a pure sine wave converter that takes the ac from the wall and rebuilds it to a new sine wave 180 degrees to the original... ie a ups. i dont know if this is a good idea though.
WerTicus-By no means do I wish to dissuade you on your quest for the perfect sine wave -http://www.tinaja.com/magsn01.aspbut I would argue that a substantial improvement in your AC lines could be provided by the simple expediency of proper application of capacitors (it is, after all, the subject of this thread). A properly rated capacitor accross your line-neutral, and additional capacitance from line-gorund and/or neutral-ground, will achieve much of what is provided by costly power conditioners. ...
Ah, if it were only that simple ...You might throw in a prayer or two for improved effects. Cheers,DVV
Dejan,Your response truly puzzles me. Granted, Dezorel's "fully balanced, floating" coditioners that you so dearly love, or PS Audio's Ultimate Outlet, ridiculously described as a 'balun', e.g. a filter based upon a CMC with flanking capacitors, is certainly an excellent approach to removing the crap that polutes our mains. And it is certainly a way to go if one is concerned about adding to ground noise (though not as well as two transformers with secondaries back to back and a bog honk'n capacitor b ...
Dejan,Your points are well taken. Improvements over 'bog stock' are generally easy and inexpensive, if you know what you are doing. But taking your system, whether power, amplification, or source to the next level become increasingly difficult and expensive..
According to a couple of pro modders, the Jensen is even better than the Blackgate when used on an amp or cd player ps.The cost on these is 50.00 for any size which makes the larger sizes a bargain when compared to Blackgates
