VB8 spikes with VB1 pads
0 Members and 1 Guest are viewing this topic. Read 1804 times.
RAW
« on: 17 Feb 2007, 08:20 am »
Here is the VB 8 spikes installed above on a pair of LX II speakers
VIBE BUSTER 8 is an audiophile quality, adjustable 3/4" O-ringed solid brass spike, which is threaded into proprietary base molded from specially formulated nylon.
To ensure complete neutrality, an O-ring was added and is placed into a special O-ring chamber in the nylon base.
The brass spike, nylon base and the O-ring work in conjunction to ensure complete elimination of vibration in any point of adjustment.
below the VB8 spikes with the VB1 pads (used for hard surfaces) installed on a pair of LX II
These VB1 pads can also be used to isolate your sources such as CD, DVD players from any vibrations
Vibe Buster 1 dramatically improves speaker performance by eliminating vibrations on micro and macro levels. The result is the ultimate enhancement of sonic reproduction of any speaker system in any listening environment
« Last Edit: 17 Feb 2007, 08:30 am by RAW »
