Lyngdorf amp reviewed in TAS
ekovalsky
« on: 17 Feb 2007, 07:00 am »
Good review of Lyngdorf TDA2200 in the March 2007 TAS (#170).  Guts are basically identical to the TacT 2150 amps.  Different DSP and room correction thanks to the bad blood between Boz and Peter.  Room Perfect and latest TacT correction software simplifies the process, vastly reducing time and effort required by the user.  Neither can match the precision and resolution of the classic TacT correction process which admittedly is very time consuming and requires mastery of rather complex software.
I hope R.E.G. gets to hear a modded TacT or Lyngdorf amp at some point.  In stock form these Tocatta/TI based amps are capable of good but not great performance; with fairly cost effective mods (on the order of $2300 per amp) they transform into something quite exceptional at least when used with a high quality digital input.
Telstar
Re: Lyngdorf amp reviewed in TAS
« Reply #1 on: 3 Dec 2007, 11:13 pm »
Which kind of mods?
Did you check the TDAI 2200? It seems improved vs the 2150.
