0 Members and 1 Guest are viewing this topic. Read 7525 times.
John, what is the advantage of the digital loop you speak of ?Mark
Surfed the net for awhile looking for a sound card (not totally knowing what all I need), and found this:http://www.amazon.com/Creative-Sound-Blaster-X-Fi-Platinum/dp/tech-data/B000AYKP6U/ref=de_a_smtd/105-1812327-1957227I've not found good pictures/discriptions of the outputs. They'll say 5.1 or 7.1 output, but in the case of some of them, there isn't enough physical jacks on the back to have 6 or 8 ouputs. Assumed it's optical, but they aren'y very specific....John you mentioned ASIO, this one is ASIO 2.0.....?Yea, all boxed up in a nice package with a bow would be nice.Anyone found good links to cards? (with pics)Bob
Quote from: Mark in NL on 20 Feb 2007, 05:00 pmJohn, what is the advantage of the digital loop you speak of ?MarkIt's actually a disadvantage that you have to do it. For internally generated sound (computer sounds,playing music from your harddrive, etc), your computer needs to have a device identified for output.In my case it's the spdif out on my 410 card. The Allocator program needs a source of input. I setmy input as the spdif in on my 410 card, so I loop the output from the computer back into the digitalinput to go to Allocator. It makes multiple copies, does its thing to each, and I route them to theanalog outs on the 410. Since it stays digital using the same clock all the way to the DAC's in front ofthe analog outs in the 410, the routing is of no consequence.At first I was sending the original signal to the digital out of my old on-board soundcard, and connecting thatto the digital in on my 410, but my old Delta card recently crapped out on me, so I had to do the loop. Theold way was actually better for me, because it gave me another set of outputs.
If i understand you correct, the digital loop loses you one dig. input and one dig. output on your card.....and it looks like there is no way around that.
