0 Members and 1 Guest are viewing this topic. Read 6669 times.
Hello all,I'm seriously considering the ACA 2b pre, and was hoping some of you owners out there could comment on how quiet it is. I have an ASL 300B amp driving Klipsch LaScalas. The LaScalas, at 104 db 1st/1mt, are ruthlessly revealing of upstream noise. The ASL is a very quiet SET amp, so I want to make sure the pre adds as little (or no) noise as possible. I'm using a tube pre now that was described an another forum as "dead quiet," but I can easily hear hum from my listening position with the volume only a quarter open.So....for you ACA owners out there, if you turn the volume up wide open with no music playing, can you hear hum in addition to the normal tube hiss?Any other comments on sonic quality would be much appreciated. Thanks!Dan
I have been running the 2B for about 2.5 years now. It took me some time to find a good set of tubes , did not like the Sovteks(dull), JJ/Tesla were better but a bit noisy and I have eventually settled on the Philips NOS 6dJ8 tubes (tried a few pairs, until I settled on a pair). These are pretty good - excellent soundstage and detail. My 2B has been really quiet from the start - there is a little hum but it is not noticible from 1m from my speakers. I know the hum is from the 2B because you can mute the output. In my situation I have had more issues with the LII. I have 2 from the from first batch. The one amp blew up and I got a local guy to rebuild them - the assembly was shocking with a massive board bend in the SPS(talking 3 mm at least). So the board mountings were modified, grounding issues re-solved and SPS was fixed. At the time I was a little annoyed. Since then perfect. The hum from both LII and 2B is so low that I don't hear it at all when playing music - even classical or soft background music. I must be one few Norh customers around. Both the 2B and LII are excellent audio products. The depth, bass and clarity are superb
Hi RayI live down under (OZ) and eventually went to a local dealer specializing in tubes. Like Steve indicated, not every tube works with the 2b. I even tired a set of matched Telsa military NOS tubes (bloody expensive) - totally unuseable, the feedback was bad. The dealer I worked with provided me the philips tubes. These are very quiet and work well with the 2b.
Hi RayI purchased the standard Philips NOS version. Regards Anthony
