The next great ART product?
0 Members and 1 Guest are viewing this topic. Read 1723 times.
Brad
« on: 16 Jul 2003, 10:36 pm »
Wayne,
Have you seen the ART Phono preamp?
I wonder if it's a candidate for modding  :idea:
http://www.zzounds.com/item--ARTDJRPRE
Looks like it's about $40......
Wayne1
« Reply #1 on: 17 Jul 2003, 04:03 am »
Brad,
 I did see it. I ordered one in from Full Compass to take a look at it about the same time I ordered the Hagerman Bugle.
It uses one 4558 IC, 1 diode for rectification on the PS and a bunch of cheap electrolytics for couplng.
It really isn't going to be any better than the phono section in a cheap receiver.
Everything on the board would have to be ripped out and replaced. You would be paying $40.00 for a circuit board with not that great a circuit on it.
The Bugle is the best buy in a phono section.
I have been listening to the MMF-5 through mine and it sounds outstanding!
I will be using it with a K&K Audio step-up transformer with my new Shelter 501 MK 2 for awhile until I get the Cornet built.
Brad
« Reply #2 on: 17 Jul 2003, 04:18 am »
Hey Wayne,
Thanks for the report.  I thought it was worth a look.
Looks like you're a couple of steps ahead, as usual :wink:
I've heard great things about the Hagtech gear - which looks more focused on sound quality.   I like the battery power supply in the bugle, too.
