0 Members and 1 Guest are viewing this topic. Read 9035 times.
I'm looking for an amp new or used to power a 5.1 home theater setup. Would like to keep the price under $2000. Any ideas or opinions on what the best amp would be. Should be minimum about 125wpc all channels driven. Solid state would likely be best. Speakers are Selah Audio rated to 84.5db 5-6 ohm fronts, 89db 3-4ohm center, plus rears and a powered sub. Currently just a Yamaha receiver RX-V496. I've been looking at Preamps such as Proceed, Cary Cimema and Nuforce, but not to up on the AMP side of things.
Quote from: musicman06 on 16 Feb 2007, 08:52 amI'm looking for an amp new or used to power a 5.1 home theater setup. Would like to keep the price under $2000. Any ideas or opinions on what the best amp would be. Should be minimum about 125wpc all channels driven. Solid state would likely be best. Speakers are Selah Audio rated to 84.5db 5-6 ohm fronts, 89db 3-4ohm center, plus rears and a powered sub. Currently just a Yamaha receiver RX-V496. I've been looking at Preamps such as Proceed, Cary Cimema and Nuforce, but not to up on the AMP side of things.Just keep in mind that if you have room for future expansion to 6 or 7.1 channels... there are already a few Blu Ray HD movies with 6-7.1 discrete channels of uncompressed audio.Its going to be more common now on Blu Ray ..than it was with dvd.
All it takes is another amp assuming your processor has the capability. It seems to me for most people finding room for six loudspeakers is difficult in a typical room that has to serve multiple purposes. The 6.1 & 7.1 are even more difficult to obtain without a dedicated room. Sometimes I wish the industry would just chill and maximize the formats we have before adding more widgets to the mix.
