A/V1RS Question
0 Members and 1 Guest are viewing this topic. Read 1310 times.
Ronno6
A/V1RS Question
« on: 14 Feb 2007, 07:59 pm »
Should A/V1RS speakers be built as right and left, or does that really matter? If so, should they be palced on the wall with the tweeters towards the center or the outside ?
RAW
Re: A/V1RS Question
« Reply #1 on: 14 Feb 2007, 08:25 pm »
Good question.
We did ours so the tweeter was to the rear of the room as we have a 12 foot long wall behind were the RS is mounted.
But if you are placing them beside you or behind you on a side wall I would put the tweeters to the front.
If you are in a small area with mounting them behind you and on the wall above your seating location I would fire the tweeters to the opposite walls for reflection.
Hope this helps
TomS
Re: A/V1RS Question
« Reply #2 on: 14 Feb 2007, 08:29 pm »
All four of mine have the woofers to the corners.  Tweeters fire inward in the back and forward on the sides.
Danny Richie
Re: A/V1RS Question
« Reply #3 on: 14 Feb 2007, 09:43 pm »
You are so far away from them it really won't matter. It would be like taking an on axis measurement of an A/V-1 from 15 feet away then flipping the speaker over (upside down) and taking another on axis measurement. Room reflections aside it would be nearly exactly the same.
