0 Members and 1 Guest are viewing this topic. Read 11877 times.
I would suggest that you order pairs of each to audition, and make up your mind.
Quote from: Dmason on 9 Feb 2007, 03:15 amI would suggest that you order pairs of each to audition, and make up your mind. I'd imagine you could sell whichever one you didn't keep for something close to 75% of retail....
Dave Dlugos from Planet 10 did a shoot out between the two drivers. He felt the B200 held the edge by a wide margin. He posted his observations on the Hawthorne Forums. Keep in mind the SI crossover has been updated since then.
Quote from: Wind Chaser on 9 Feb 2007, 01:02 amDave Dlugos from Planet 10 did a shoot out between the two drivers. He felt the B200 held the edge by a wide margin. He posted his observations on the Hawthorne Forums. Keep in mind the SI crossover has been updated since then.I had to comment on this. Dave Dlugos is a great guy and very fair, but this comparison was done in such a way as to invalidate it. The SI was placed on a huge baffle with big wings. This is not even close to the recommended narrow flat or very small winged baffles that it is recommended for use with it. A big winged baffle will cause the bass of this driver to over-power the mids, which causes a muffled, almost low resolution sound. On a small narrow baffle the SI sounds much much better.
