Art Di/O with Jolida 1501RC integrated
0 Members and 1 Guest are viewing this topic. Read 1543 times.
Sal6
« on: 15 Jul 2003, 03:33 am »
Am expecting delivery of an Art Di/O this week and wonder if someone can tell me if this amp will have a problem with the output from the Art?
I plan to get the mods, but want to try it out and get some idea of its operation, but don't want to blow my amp in the process.
Wayne1
« Reply #1 on: 16 Jul 2003, 04:01 pm »
Sal,
There is not too much chance you will blow up your amp with the DI/O plugged into it.
The high output of the DI/O may distort your input stage, but that is about it.
Depending on how the Jolida is put together, you may have the volume control before the input stage. If that is the case, then all is well. You will have a very small amount of control over the volume, before it gets too loud, but that is all. If the input stage is before the control, then the gain stage may be overloaded by the DI/O. All that will result in is distortion, not damage.
Even the stock DI/O does not sound that great out of the box. It takes about 100-150 hours of constant signal going through it before it really opens up.
It takes quite a bit longer with the modded versions. As I replace just about everything that gets broken in, you have to start all over again. It will take anywhere between 400-650 hours of constant signal through a modded unit before it really shows what it can do.
OBF
« Reply #2 on: 16 Jul 2003, 10:03 pm »
I used to have that same combo for a while, and I'm not positive, but I think it worked ok.  It definitely caused static or crackle on my friend's Outlaw receiver.
