watching video from computer on tv?
0 Members and 1 Guest are viewing this topic. Read 1251 times.
sts9fan
« on: 7 Feb 2007, 02:45 pm »
So does anyone know of a good USB > Componet converter.  I want to watch video from my computer on my DLP tv.
thanks
JohninCR
Re: watching video from computer on tv?
« Reply #1 on: 7 Feb 2007, 04:00 pm »
I use a Zinwell bls3000 as my video hub. The inputs are composite video, S-Video, component video, coax (cable TV), and RGB (computer monitor).  Then it outputs RGB, S-video, or component video.  I input everything including my computer (via an A/B monitor switch), and then output to my projector using the RGB out.  It includes upscaling so my standard DirecTV is output at near DVD quality, and DVD quality is enhanced.  Since it doesn't handle hi-def it's outdated, so you may be able to pick them up cheap.  I doubt that USB can output high quality, even if you found a converter.  I'd think you're looking at S-video at best.
DonnieW
« Reply #2 on: 15 Feb 2007, 12:16 pm »
thanks
Why USB?  Why not get a video card that does component out?  You can go 30'-40' of component cables using RG6 if length is an issue.
zacster
« Reply #3 on: 15 Feb 2007, 01:12 pm »
AppleTV.  Forget about the cables.
