Caddock Resistors and PCB
0 Members and 1 Guest are viewing this topic. Read 1315 times.
machine
« on: 6 Feb 2007, 10:52 pm »
I bought a Cornet2 Kit and it came with Caddock MK132 resistors.
These I guess are on a .20" centers where the PCB has standard .50" centers.
What is the best way to solder these guys on?
SET Man
Re: Caddock Resistors and PCB
« Reply #1 on: 7 Feb 2007, 01:55 am »
Hey!
  The same way you do with other resistors. Just spade those legs out and solder them. Or you could just bend those legs to make it look neater. :D
   BTW... for best soldering and connection. Do use xacto knife to lightly scrape those legs where the solder will be before solder. :D
Take care,
Buddy :thumb:
machine
« Reply #2 on: 7 Feb 2007, 10:07 pm »
Thanks SETMan!
Thats what I thought I had to do.
No worrys about picking up noise?
A few of these have very short leads, will be fun to try and deal with them.
I have the AuriCaps and was wondering if it would be worthwhile to upgrade to SoniCaps?
