No Rez Usage
0 Members and 1 Guest are viewing this topic. Read 2217 times.
BRN
No Rez Usage
« on: 4 Feb 2007, 06:50 pm »
When using No Rez, do you remove the polyfill for the speaker cabinet? Also, should it be used on all surfaces including the front baffle?
TomS
Re: No Rez Usage
« Reply #1 on: 4 Feb 2007, 07:00 pm »
I put it on all the exterior surfaces that were large enough, then re-filled with poly fill.
srb
Re: No Rez Usage
« Reply #2 on: 4 Feb 2007, 08:07 pm »
Uh-oh.  I've been putting it on the interior surfaces. :wink:
Danny Richie
Re: No Rez Usage
« Reply #3 on: 4 Feb 2007, 09:12 pm »
How about on all of the interior (inside) of the outer walls. You will not need to put it on any braces.
BRN
Re: No Rez Usage
« Reply #4 on: 4 Feb 2007, 09:29 pm »
What about the polyfill? Do I sitll need it or does the No Res take its place?
Danny Richie
Re: No Rez Usage
« Reply #5 on: 5 Feb 2007, 03:40 pm »
Typically I still like to add a loose wadding of polyfill or fiberglass insolation.
