Bugle PS problem
0 Members and 1 Guest are viewing this topic. Read 1211 times.
bobcole
Bugle PS problem
« on: 4 Feb 2007, 04:02 am »
Been running the Bugle on batteries for a year, but finally got around to finishing the power supply. It sounds good, but am only getting 13.5 millivolts (yes, mv) on the minus side. Plus side is 14.8 volts. Tranny gets very hot after 20 minutes, as does the voltage regulator on minus side. Plus side is cool.
Where should I start?
hagtech
    • http://www.hagtech.com
Re: Bugle PS problem
« Reply #1 on: 4 Feb 2007, 05:52 am »
You have the negative outputs wired backwards.  Shorted to ground.
jh
bobcole
« Reply #2 on: 4 Feb 2007, 11:00 pm »
Ooops! Thanks, Jim - maybe I'll get it right the second time.
