Audio/Video Gear and Systems
The Acoustics Circle
Rob Babcock
WHat are the DIY options for diffusers?
0 Members and 1 Guest are viewing this topic. Read 1426 times.
gonefishin
3 Feb 2007, 10:19 pm »
Hi guys,
I'm wondering what are the DIY options for diffusers?
thanks,
dan
woodsyi
Volunteer
Always Look on the Bright Side of Life!
Re: WHat are the DIY options for diffusers?
3 Feb 2007, 10:57 pm »
Did you say DIY? Then there must me a Jon Risch solution.
http://www.audioasylum.com/audio/tweaks/messages/1725.html
Also, here is an article that concisely explains quadratic residue sequence and a depth sequence generator.
http://www.phy.mtu.edu/~suits/diffusers.html
Good luck.
Rob Babcock
