Stuff and Damp- How much?
0 Members and 1 Guest are viewing this topic. Read 1362 times.
simsalabim
« on: 14 Jul 2003, 01:56 am »
According to this informative article,
http://www.silcom.com/~aludwig/Loudspeaker_construction.html
"the interior was filled about 50% with fiberglass (the garden-variety type used to insulate houses). The fiberglass filling reduces the panel vibration by about 20 dB across the entire frequency range. This corresponds to absorbing 99% of the sound energy, at a very low cost, and with very little effort. And it kills internal standing waves. The lesson here is real clear: stuff the enclosure with fiberglass"
If true, it seems to beg a few questions, in my newbie mind at least:
1. What's the point of worrying about box volume if you end up stuffing it so much - IOW, wouldn't a smaller stuffed box be as good a larger stuffed box?
2. I've seen a post about the effect of stuffing in ported vs. sealed boxes and can't remember what was said...  One of them increases virtual volume, one decreases... which is which and is there any formula or data about how much to stuff?
Thanks in advance for any input.
