0 Members and 1 Guest are viewing this topic. Read 6659 times.
Hey where do I get the right "Rope Mortite" in the Bay Area?
Quote from: refmedia on 31 Jan 2007, 06:56 pmHey where do I get the right "Rope Mortite" in the Bay Area?I only know two companies that make it...Mortite (the original) and Dennis. I think Dennis is sold thru Ace Hardware stores in Bay area (I'm in Marin Co.). I found it much more readily when I lived back east, but can still be found in 50% of the hardware stores around here. Generally, it's in the Paint aisle, but not always.
They putty is interesting to adjust and plays a huge roll in the placement of the speakers or subs. I personally love the way VMPS uses the slot loaded passives, like the L-pads tune to taste. John Casler might be able to chime in here as he must be a "putty master" by now with all his subs. Here are some pics of interesting set ups that may work better with more putty. Haven't done sweeps yet not sure I need too The bass is so resolving, clean and lush I can taste it in a couple of configurations. The subs always seems to sound better front firing on the same plane as the Towers IMHO. Wall and corner placements are okay and may go deeper but create an obvious delayed bass attack in my system.
How about PR's firing at the ceiling? Or the 12 and 15 firing at the ceiling?The combos are endless and all fun to try. Right now my front largers are about 5 feet off the ground!!!!
If your bass is woolly you may want to try to take some putty out. It's a balance and most people tend to leave too much in. If you've already removed over a quarter inch diameter it may need more added. You'll learn to hear the difference with a little time. You'll also notice the lower midrange is also affected and this helps dial them in easier.Glad you're happy with your 1,500 dollar mini monitors. For that kind of money you got a steal
Hey refmedia,I see you are using Behringer A500 amps for the subs, how is that working out for power/control/quality of bass sound?Thinking of using them for my patio ceiling sub and bass drivers in my main room speakers.That is a lot of speakers in 1 room , coooool
I had a Carver ZR1600 which was my first pro amp, and it was great, 18A fuse and a ton of power, but alittle to expensive for a patio system.I am also looking at behringer's 1500 and 2500 incase more power is required , but it doesn't seem like it.If you don't mind me asking, where did you get them and for how much?Thanks J
John it is truly mind boggling the amount of combinations you can do with four largers and some phase switches. I am sure you have created some bass sculptures of the finest order. Question does your crossover have continuously variable phase or a simple invert? The X over I am using only has invert. A nice varable knob might be cool for slight offsets of the phase.I have tried a few of your suggestions and even long and short walls in out of phase.Quote from: John Casler on 31 Jan 2007, 11:35 pmHow about PR's firing at the ceiling? Or the 12 and 15 firing at the ceiling?The combos are endless and all fun to try. Right now my front largers are about 5 feet off the ground!!!! I have not tried the passives or actives up yet will do..... and all four at 5 feet The things you can do with low end bass in a room is totally fascinating.Sound effects like race cars cannons and helicopters when you charge the room in unusual ways is just breathtaking.Not to mention certain music.Thanks for the tips I will experiment!
Yes my x-over has "variable" phase, as well as several other great controls (NHT X-2)For a lot of "experimentation" it is a great help.All 4 of my LARGERs are not at 5 feet, only the fronts. The rears (behind my listening chair) are still on the floor.I had a long conversation with Kevin Voeks about a year ago, who has the luxury of HARMON intl's money to experiment with, and I told him I was thinking of raising one pair off the floor, and he said they were experimenting with subs in opposite corners of the room (rears in the corners on the floor, and fronts in the corners, but at the ceiling) and at varying heights. The idea was to load the room with bass energies from significantly differing source positions to alter the paths and room reactions, so that cancellations and peaks were different, which helps in smoothing the responses in a particular area.As well I am single and can "get away" with most any tweak without concern to WAF
