Hook-up Wire - 41hz Amp4; Advice Please!
0 Members and 1 Guest are viewing this topic. Read 1561 times.
Reverie
    • My Myspace
« on: 28 Jan 2007, 01:09 pm »
Hey all,
Yet again, another post about how to finish off the 41Hz amp4 kit I'm modifying.  :oops:
Basically, I'm considering what wire/cable to use for the signal path wire for the input, power (from an SLA battery) and output signal paths.
As for gauges, I'm considering using AWG16 for the output and power, and AWG23 for the input, as I'm aware these are generally preferred for these uses.
I had originally planned to use hand drawn .999% silver insulated with beeswax-permeated cotton from Electrum Audio. I was assured the wire would not suffer from the usual 'brightness' associated with silver, and that the detail and 'soundstage' would be much increased.
However, I then found out that braiding the wires has a noise-cancelling effect, which is particularly important in class D to remove switching noise. I'm not entirely sure if braiding of the Electrum Audio wire would be possible. Considering this, I thought perhaps Cat5e cable would be a good idea, as I've heard many people rave about this being suitable for speaker cable wire.
Additionally, I've seen many good wire products from both Percy Audio and Diyaudiostore, but I'm still rather lost as to what to go for.
In other words, any help/recommendations would be much appreciated!  :D
Peter
« Last Edit: 28 Jan 2007, 02:47 pm by Reverie »
Gordy
Re: Hook-up Wire - 41hz Amp4; Advice Please!
« Reply #1 on: 28 Jan 2007, 02:27 pm »
I've used Chris Ven Haus's bulk wires with great success in several amps and see he now has a mini coax that might work well for your inputs... http://www.vhaudio.com/wire.html
Reverie
    • My Myspace
« Reply #2 on: 28 Jan 2007, 02:49 pm »
Thanks for the reply, I'll go check the site out.
Also, I just noticed I didn't put that the power source will be a SLA battery, which will probably have an effect on the wire choice for it (being DC and not AC).
« Last Edit: 28 Jan 2007, 07:53 pm by Reverie »
