Community
Non-audio hobbies and interests
The IT Crowd
GentleBender
New Slimserver install: how to stop the firware update alert?
0 Members and 1 Guest are viewing this topic. Read 1083 times.
tonyptony
27 Jan 2007, 05:07 pm »
I just installed 6.5.1. It all went fine, but I want to continue to use the firmware vesion that was already installed on my SB3. How do I tell Slimserver to stop alerting me to install the latest firmware?
gitarretyp
Re: New Slimserver install: how to stop the firware update alert?
27 Jan 2007, 05:09 pm »
You need to edit <path to slimserver install>/Firmware/squeezebox2.version and replace all instances of the current FW with the one you want. You must have your preferred FW file in the Firmware directory, also. Then restart (or start) slimserver.
mcgsxr
Mark in Burlington, Canada
Reply #2 on:
27 Jan 2007, 05:46 pm »
http://www.audiocircle.com/index.php?topic=26453.0
Try this firmware piece that mgalusha built, it is perfect for what you are trying to do!
tonyptony
Reply #3 on:
27 Jan 2007, 06:13 pm »
Thanks gitarretyp, that did it.
mcgsxr, I already have mgalusha's Firmware Selector, but I wasn't sure if even selecting the one already installed wouldn't reinstall it, which I did not want to do.
Community
The IT Crowd
GentleBender
