Custom Speakers for HT
0 Members and 1 Guest are viewing this topic. Read 12007 times.
Bingenito
Re: Custom Speakers for HT
« Reply #20 on: 18 Feb 2007, 08:57 pm »
Gross is 3.5cuft. Net is about 3cuft. With the right stuffing and EQ it will be just right.
Lindahl
« Reply #21 on: 28 Feb 2007, 08:20 pm »
I placed my order today for the 3 kits. Hopefully I'll be able to finish them in 2-4 weeks (mostly just weekends). By then, a pair of TC-3000s (on sale right now) should have arrived, and I can begin building two sealed ~3.5cuft boxes for them, each powered by a buttkicker amp (1900 watts @ 2 ohms). Together it should be a pretty wicked theater system in a 2000 cubic foot well-sealed and treated room. Can't wait to hear the end result! :green:
Then I'll start on the surrounds... if I even get there after being blown away. Can you tell I'm excited?
« Last Edit: 6 Apr 2007, 02:00 pm by Lindahl »
Bingenito
« Reply #22 on: 28 Feb 2007, 08:45 pm »
Hey man I am excited for you :drool:
I think that you need about 4 more 15" woofers  :P :lol:
smithsonga
« Reply #23 on: 24 Mar 2007, 04:22 am »
in a 2000 square foot well-sealed and treated room.
Holy Smokes.  Now THAT is a theater. 2000 sq ft???  cu ft?
klh
« Reply #24 on: 24 Mar 2007, 06:40 pm »
Chances are he meant cu ft :D. 2000 sq ft is insane!
Lindahl
« Reply #25 on: 24 Mar 2007, 08:43 pm »
Yes, 2000 cubic feet, not square feet. Bryan's probably right, I'd need at least 4 more 15" subwoofers in that kind of space. Hopefully 2 will be able to keep up - looks like it will, according to this guy's experience. He's got just short of 2000 cubic feet and is hitting above reference levels (120+ db) at about the same seating distance (11 feet - 3.5 meters). I've got my fingers crossed. This will be quite a change from a lot of systems I've heard, where the speakers are struggling to keep up with the subwoofers (not even at reference levels, either).
« Last Edit: 24 Mar 2007, 08:53 pm by Lindahl »
Bingenito
« Reply #26 on: 27 Mar 2007, 10:12 am »
I was just kidding about the extra subs. My main room is about 3000 cuft and the RC5s will rattle your head without subs. The 2-15's will be sufficient in that room. No worries!
Lindahl
« Reply #27 on: 29 Mar 2007, 02:46 pm »
Once things get going, I'll be posting the build progress and measurements for both the LCRs and the subwoofers over here on AVS Forums. The subwoofers and amplifier have arrived, and Rick intends on shipping out his kits sometime next week.
Lindahl
« Reply #28 on: 29 Apr 2007, 06:21 pm »
Updates posted over on AVS forum (follow the link in the previous post). Although it's just a subwoofer update for now, I'll have speaker build updates posted in a couple of hours.
Lindahl
« Reply #29 on: 3 Jun 2007, 06:42 pm »
All done! I guess it took more than a few hours to post those updates :D. Updates were done, here, to keep all the build information in one place. Enjoy!
