0 Members and 1 Guest are viewing this topic. Read 10446 times.
Hi Phil,I use WAV files and the only missing feature is FF and REW as far as I know. The standard tags seems to work OK. Compilations appear to work as I expect. What am I missing? (I'm not using a Mac and I only rip CDs not individual songs.) regards
If you use WAV, you should be able to FF and REW fine (just make sure that the File-Types are playing the WAV files natively on the SB/TP).When I was ripping to WAV, I was finding all sorts of problems...double CDs having the first CD listed under the artist and the second one getting listed under Compilations, numerous CDs getting ripped and stored to "No Artist", etc. It sounds like you're not having this problem? I don't have these problems when I rip to Apple Lossless. And yes, I only rip full CDs.
You could have easily taken the library in existing its existing WAV format and converted it to flac, then tagged it using any of a number of tagging programs. Would have saved you from reripping, although it would have taken a fair amount of manual checking/correction of tag data.
Quote from: JEaton on 27 Jan 2007, 07:39 pmYou could have easily taken the library in existing its existing WAV format and converted it to flac, then tagged it using any of a number of tagging programs. Would have saved you from re ripping, although it would have taken a fair amount of manual checking/correction of tag data.But as I mentioned, I'm using iTunes and a Mac, neither of which supports FLAC. And once I converted to WAV, didn't I pretty much lose all the tagging data? I would have had to enter it all manually...
Just copy the FLAC files off to a neutral media - reimport then convert and allow the FLAC converter to auto-search for the tagging info - moot point now.Bryan
Strange that slim devices server software don't support apple lossless! The Roku sound bridge's firefly does.
all you have to do is organize your music in folders and always find your music by "browse music folder". Much easier the re-ripping
Quote from: LightFire on 28 Jan 2007, 02:26 amStrange that slim devices server software don't support apple lossless! The Roku sound bridge's firefly does.SlimDevices server software does support Apple Lossless....it's the actual Squeezebox/Transporter that doesn't. When using Apple Lossless, you have to have Slimserver convert the Apple Lossless file to either FLAC or WAV before sending it to the SB/TP (this is done by checking the proper setup in the File-type section)....
It looks like Apple is trying to lock your music away from your SB. Similar things happen with Roku Soundbridge, but they worked it around with their firefly server. iTunes 6 would work straight with the device, but since version 7 it has to be "unlocked" by the firefly server (it basically reads iTunes play lists and data base). No need for conversion here. The fact that you are using a Mac should not make any difference. The problem is iTunes not colaborating and/or SB software not reading Apple Lossless.
