0 Members and 1 Guest are viewing this topic. Read 16738 times.
So much for the rant. Yes the rear tweeter yields more constant directivity and also smooths the power response a little through the mid/tweeter crossover.
Waveguides to control directivity and lower distortion in tweeters used with dipoles.That sounds like a pretty good idea to me. Might have to try that someday cheers,AJ
Quote from: AJinFLA on 9 Feb 2007, 12:19 amWaveguides to control directivity and lower distortion in tweeters used with dipoles.That sounds like a pretty good idea to me. Might have to try that someday cheers,AJAJ,I'm talking about waveguides more to control directivity of mids all the way up thru the tweeter range. Initial tests show real promise.
Are these big enough for you? Note that the pentagon shaped ones for the B200 still have big roundovers to come for the mouth, and both are without damping to deal with High Order Modes caused primarily by reflections and diffraction. The mini-line is for FE108's and the rear will have a similar guide. I'm erring on the large side, until I get a good grip on behavior and can optimize the size.
