Bugle super-regulator
0 Members and 1 Guest are viewing this topic. Read 2926 times.
PatOMalley
  • This text is personal
    • http://home.comcast.net/~omaille/audio/home.html
« on: 24 Jan 2007, 09:15 pm »
Jim, I remember you talking about adding super regulators to the Bugle and it making a large difference.
Would the ones from BursonAudio be compatible?
http://www.bursonaudio.com/Burson_Super_Regulator.htm
Module #                 Voltage Range              Maximum Current Output
LM78  A                   5 – 10 V                      Output 80ma
LM78  B                   10 – 20 V                     Output 80ma
LM79  A                   (-) 5 – 10 V                  Output 80ma
LM79  B                   (-) 10 – 20 V                Output 80ma
LM317 A                  5 – 10V                        Output 80Ma
LM337 A                  (-) 5 – 10V                   Output 80Ma
LM78 C                   10-20V                         Output 150Ma
LM79 C                   (-) 10 -20V                  Output 150Ma
PatOMalley
Re: Bugle super-regulator
« Reply #1 on: 24 Jan 2007, 09:16 pm »
The super Regulators would be added to the power supply of the Bugle.
hagtech
« Reply #2 on: 24 Jan 2007, 11:08 pm »
Looks to me like the 78B and 79B models would work fine.  Choose 12V or 15V.  Then give it a nice raw supply in front of it (look at my power supply schematic for ideas).  Make sure you have enough headroom for the Bursons.
jh
markus46
« Reply #3 on: 4 Jun 2008, 01:54 am »
Hi Pat,
Did you end up fitting the Burson super regulator to the Bugle power supply?
Did you notice any improvement?
Cheers!
Mark
PatOMalley
« Reply #4 on: 4 Jun 2008, 06:21 pm »
never did. tried the burson discrete opamp and it was a nogo so i moved on. I think it might be worthwhile, though.
markus46
« Reply #5 on: 4 Jun 2008, 10:48 pm »
I've ordered a bugle and a power supply kit.
I'll use the burson regulators and report back if you are interested.
PatOMalley
« Reply #6 on: 5 Jun 2008, 02:15 pm »
absolutely. let us hear about it.
