7B SST current draw
0 Members and 1 Guest are viewing this topic. Read 4249 times.
caleb
7B SST current draw
« on: 24 Jan 2007, 09:50 am »
I have had great pleasure from my 7B SSTs over the past two years.
I have posted here the fact that on turn on they make a buzzing sound - and the replies have always been "no problems".
However, last week I put a power conditioner into my equipment, and although it is rated at 1500 watts - it will not allow my Brystons to turn on - it just keeps switching off.
Can anyone tell me what the current draw at turn on should be??
Surely not more than 1500 watts???
Regards
CBW
  • The Demo is Everything!
    • http://www.bryston.com
Re: 7B SST current draw
« Reply #1 on: 24 Jan 2007, 12:08 pm »
Hi CBW,
What power conditioner?
james
« Reply #2 on: 24 Jan 2007, 04:21 pm »
Regards
CBW
Hi CBW,
Toroidal transformers draw large amounts of current on turn-on. In the case of the 7B SST at 240 volts the turn on surge (with our SOFTSTART circuit) is about 35 amps each.
My guess is that the circuit breaker in your power conditioner will not accept the short term current draw of 70 Amps (2 times 35 amps) where the circuit breakers in your home had no problem with it. The Torus power conditioners have circuit breakers designed to accept these short term draws without activating.
james
PS- this inability to deliver short term high current was why we did not recommend using powerline conditioners with Bryston amps until we developed the TORUS units. Musical transients also require the delivery of short term very high current peaks from the amplifier.
« Last Edit: 25 Jan 2007, 12:22 am by James Tanner »
caleb
« Reply #3 on: 25 Jan 2007, 03:26 pm »
Hi CBW,
james
Hi James,
I bought the PS audio Premier Power Plant
Hope this helps.
« Reply #4 on: 25 Jan 2007, 07:20 pm »
Hi CBW,
james
Hi James,
Hope this helps.
Hi CBW,
I had a look at the PS. The input breaker maybe 6A.
On turn-on the two amps may demand 16,800W (240V x 35A x 2 - more than 10X the Power conditioner's rating). While this is a very short term condition (generally less than 1/2 cycle, 0.01 seconds @ 50 Hz), it may be long enough to trip the power conditioner's breaker. The more distant panel breaker would be slower to trip because of the line impedance.
A Torus International 8A Power Isolation Unit is rated at 1920VA, but its Load Current Capability is much greater, it can supply 500A for 1/2 cycle (120,000W), 250A for 1 second and 125A for 10 seconds. Beyond that, it will make the amplifiers sound better than ever. The low impedance output coupled with a huge magnetic flux-field supplies amplifiers all of the juice they want without sagging the voltage the way that plugging into the wall will. Most power conditioners limit power, their benefits of filtering or regulation are lost on large amplifiers. This is not the case with Torus PIUs which provide huge current as well as the best noise and surge suppression available.
The PS is a power regenerator and the surge suppression is MOV-based so I would not recommend it for use with our power amplifiers.
james
« Last Edit: 25 Jan 2007, 08:23 pm by James Tanner »
caleb
« Reply #5 on: 8 Feb 2007, 05:08 pm »
Hi James,
Thanks for your explanation, I have now plugged my Brystons back into the wall socket, and amy saving up my pennies to get one of your Torus units.
RGDS
CBW
rollo
  • Rollo Audio Consulting -
« Reply #6 on: 8 Feb 2007, 05:25 pm »
Hey James, Have a web site for Torus Intl.
rollo
« Reply #7 on: 8 Feb 2007, 05:54 pm »
rollo
http://toruspower.com/
Bob Reynolds
« Reply #8 on: 9 Feb 2007, 12:09 am »
Hi James,
I hope you will suggest a set of Torus Power units (120V) to handle my system.
Digital sources: Arcam FMJ 23T CD player (will be replaced with a Bryston when available), Denon DVD-3910.
Preamp: BP26
Amps: (2) 7B SST
Video: Sony 32" CRT (will probably be replaced with a ~40" plasma)
Subwoofer: M&K 5310 dual 12" 600W peak class AB amp
Bass Management Controller: M&K LFE-4 (will probably add a Velodyne SMS-1 this year)
In a previous post you had said that digital components should optimally use a separate Torus unit. Would video use the same unit?
Any general comments would be appreciated.
Bob
« Reply #9 on: 9 Feb 2007, 12:37 am »
HI Bob,
The 15 or 20 amp unit would be ideal for all the equipment or it your wanted total isolation a small 5 amp unit for the digital and video gear.
james
Bob Reynolds
« Reply #10 on: 9 Feb 2007, 03:51 pm »
HI Bob,
james
Thanks James.
Levi
« Reply #11 on: 9 Feb 2007, 04:16 pm »
I want to buy a 15 or the 20 amp unit.  Can I buy them direct?
« Reply #12 on: 9 Feb 2007, 07:03 pm »
Hi Levi,
Sorry nothing direct -  the Torus is only sold through Torus or Bryston dealers.
james
