can i
0 Members and 1 Guest are viewing this topic. Read 1511 times.
gypsums
can i
« on: 23 Jan 2007, 08:56 pm »
can i connect a sub to my p-8?  as experiment, i only have small speakers so it may be a good test for my room to see if floor standers would be a better option in the future..
nuforce-casey
Re: can i
« Reply #1 on: 23 Jan 2007, 11:20 pm »
Yes you could, but you need to somehow be able to set the crossover point:
Option 1)  Running the smaller speaker full range,  2)  Run the smaller speaker in high-pass mode.
gypsums
Re: can i
« Reply #2 on: 26 Jan 2007, 07:34 pm »
that sound to technical so i will give it a miss.
ooheadsoo
Re: can i
« Reply #3 on: 26 Jan 2007, 07:36 pm »
How is that more technical than any other subwoofer setup?
