Other Stuff
Archived Manufacturer Circles
Response Audio
Bella EXtreme 3205 MK II - Cosmetic B-Stocks
0 Members and 1 Guest are viewing this topic. Read 1945 times.
Bill Baker
Industry Participant
Musica Bella Audio- Custom Design and Manufacturi
23 Jan 2007, 04:09 pm »
Hello AC'ers. I have gone through a few of the chassis used in the assembly of the Bella EXtreme 3205 amplifiers and have a few that are less than perfect. Actually, none of the chassis used for these amps are *perfect* as mentioned on my website but these are
slightly
more noticabe.
I have two chassis left that have some imperfections in the paint surface on the top of the chassis. This is obvioulsy only cosmetic and in no way effects the performance of the amps. I have tried to photograph the surface of the chassis but unable to capture the blemishes. Think of an automotive bodyman that didn't do a perfect job of sanding smooth the Bondo and painted over it.
Special AC price on remaining two units is $1350 supplied with either tube type.
Information:
http://www.bellaextreme.com/bella3205.htm
Bill Baker
Re: Bella EXtreme 3205 MK II - Cosmetic B-Stocks
24 Jan 2007, 11:00 pm »
Last Call. Only one left. Like the most recent piece to go, I will also include shipping.
Next run of these amps will not be till early-mid March as the benches are getting pretty full.
smccull
Reply #2 on:
10 Feb 2007, 05:20 am »
Bill,
Could you add a volume control to one of these to make it a one input integrated? Or perhaps on a new one?
Bill Baker
Reply #3 on:
10 Feb 2007, 02:12 pm »
Hello Steve,
Yes, these are available with a volume control. The volume knob can be mounted anywhere that is convenient for you. I use the ALPS Blue. The addition cost would be $65.
My personal unit uses a single input with volume.
Other Stuff
Response Audio
