Ethernet "crossover cable"?
0 Members and 1 Guest are viewing this topic. Read 2170 times.
PhilNYC
« on: 21 Jan 2007, 03:48 pm »
Anyone know what the difference is between an Ethernet "crossover" cable and a regular Ethernet cable?
I'm trying to hook my Squeezebox to my TIVO box...the instructions say to use an Ethernet crossover cable, and I'm wondering if my drawer full of regular Ethernet cables will be sufficient...
bpape
    • Sensible Sound Solutions
Re: Ethernet "crossover cable"?
« Reply #1 on: 21 Jan 2007, 04:01 pm »
They're not the same - sorry.  Most devices will autodetect whether the cable is std or xover and adjust internally - yours evidently doesn't.
Here is a link on how to wire the std vs the xover version.
http://www.ertyu.org/steven_nikkel/ethernetcables.html
Bryan
F-100
« Reply #2 on: 21 Jan 2007, 05:00 pm »
A crossover Ethernet cable have different ends and is used to connect two Ethernet devices without a hub.
bpape
« Reply #3 on: 21 Jan 2007, 05:02 pm »
Agreed.  Most ethernet devices now though do not require a crossover cable as they're autosensing and will do the xover inside the unit on one end to get the proper connections.
Bryan
Porter
« Reply #4 on: 27 Jan 2007, 03:18 am »
And note that only one of the devices needs to have this capability in order to work.
You should try hooking it up with a standard ethernet cable and see what happens.  The Squeezebox uses a modern Ethernet chipset, it should do the xover on its own.
JEaton
« Reply #5 on: 27 Jan 2007, 07:46 pm »
I'm pretty sure that neither the Squeezebox or TiVo do auto-mdx, but it can't hurt to try it with a standard straight-through Ethernet patch cable.
