Wayne, have you measured your cables for capacitance?
0 Members and 1 Guest are viewing this topic. Read 1661 times.
dogberry
Does it matter to you?
Obviously they sound good to your ears (and all your customers!).
I notived a big difference between your old digicable and your new one (with Bullet Plugs).  That doesn't happen to me often.
I wanted to see how many other cable manufacturers were using Bullet Plugs and noticed a lot of these guys mention capacitance.
Just curious.
Wayne1
« Reply #1 on: 11 Jul 2003, 03:46 pm »
The capacitance of the digital cable is 16.2 pF/FT
The main difference in sound between the Bullet Plugs and the Canare isn't capacitance, I believe. It is the lesser amount of metal surounding the signal bearing conductor. Having a hollow center conductor and just a small pin for the ground connection reduces the amount of interaction of the magnetic fields generated by the signals. I feel this is what accounts for the less "smeared" sound of the Bullet Plugs.
dogberry
« Reply #2 on: 11 Jul 2003, 04:14 pm »
Is this true for analog cables as well?  What do you think are the hallmarks of the M-80s?  Right now I'm using Coincident CST ICs, but I think I might have the Bullet Plug bug.  :?
