0 Members and 1 Guest are viewing this topic. Read 1723 times.
Any ideas on what "wood" (i.e., particle board?) to use and what thickness to use for the bottom of a slot for a Larger? I purchased two used Largers, one of which does not have a bottom (and I think is miswired, but that's another story). Thanks.
I think it's just 1/2" MDF. You can probably cut one to size and paint it black. While you have the slot open, stand it on it's side and play around with it. You will get some interesting result. You may even like it.
