Same Vd, different size drivers - is bigger better?
0 Members and 1 Guest are viewing this topic. Read 2203 times.
rick57
« on: 19 Jan 2007, 09:54 am »
Some have suggested (IIRC at the AA's High Efficiency Speakers or diyaudio) that bass from larger, lower xmax drivers, sounds better (more effortless? ~ lower IMD??) than from a smaller driver of the same Vd.
If beaming is not an issue, in a dipole over say 70 - 400 Hz, would the same Vd from eg a 15" be preferable to that Vd from a a higher xmax 10/ 12"?
thanks
rick57
Re: Same Vd, different size drivers - is bigger better?
« Reply #1 on: 20 Jan 2007, 12:32 am »
Curiosity got to me, and I posted the same question at diyaudio. Some good points there:
http://www.diyaudio.com/forums/showthread.php?s=&threadid=94591
almost a consensus
Cheers
JohninCR
« Reply #2 on: 20 Jan 2007, 02:49 am »
Rick,
I don't have an explanation, but I have to agree with MBK over at DIY, that larger pro-type drivers make better OB bass and do sound different.  One thing not mentioned is that with the smaller driver driven to high excursion, it is far more likely to have noise in operation.
rick57
« Reply #3 on: 20 Jan 2007, 05:02 am »
John
Could you say how they sound different?
Peter Clements
« Reply #4 on: 20 Jan 2007, 10:04 pm »
I have found that 2 of low vas 18" is even better. Best bass by far and cheaper to boot.
« Reply #5 on: 22 Jan 2007, 12:54 pm »
Large drivers would have less travel to create equal Vd, and so if the larger driver's moving mass were low enough it should provide better dynamic response (create the Vd faster than a smaller driver).  One of the advantages of line array's is that you have multiple smaller drivers (with lower moving mass) with less travel.  As with most everything in audio, there's trade-offs involved.
