Hi DVV,
actually i was joking (only teasing, I know it's not really what you want to do!), but hey you're suggestion is pretty good.
Best regards
Raj
Wrong Raj, actually, I'd love to do that. For example, put my trusty 1M (that's what I call it, "1M" stands for 1 MHz) into some of your hands. The problem is that I don't have an accompanying preamp for it, I'm only just starting on that.
What I want to do is make a preamp with tone controls unlike any I have ever seen anywhere. First off, they would have to act at the extremes only, without even touching the midrange, because the extremes are where we actually need them. Next, I want exactly repeatable steps in increments of 1 dB, namely -3dB, -2dB, -1dB, 0, +1dB, +2dB and +3dB; this is all that's really required to compensate for the room/speaker interaction. Lastly, I want the tone control circuit to have as little sonic signature as possible, ideally zero, but I'll settle for very hard to hear at all.
Now, I have some ideas about how to do it, but I'll have to do a lot of work before I'm satisfied. The rest, like kicking the distortion off the meter scale, hitting 2 or 3 MHz is easy, no big deal, a lot of people can do it. Of course, 2 or 3 MHz is its internal (inherent) pass band, it's externally limited to much less, typically 500 kHz (value chosen because with it, the phase shift in the 20-20,000 Hz band is less than 0.5 degrees - practically non-existent).
I would also want a variant of it with two or three parallelled outputs, internally filtered at desired frequencies, thus combining the preamp with an electronic crossover function. Opening the door to active amplification, if you like. I happen to be a great believer in the active approach.
And I would want that preamp to cost something most people could afford without selling mom and dad down the river. Say, 500 euros max, which is about $550, or about 350 quid for you, on the condition that they do NOT have to plonk down all the dosh at once, but can do it over time.
That's why I never put any project like that in public view. It has to be oustanding in my view before I start enticing people to spend money on it.
DVV
