how to wire center-tap of a Hammond transformer
0 Members and 1 Guest are viewing this topic. Read 1288 times.
CButterworth
« on: 17 Jan 2007, 04:25 pm »
I have just completed my Aikido preamp, and have got the hum down to tolerable levels.  However, I have now realized that maybe I need to do something with the center-tap of my Hammond transformer.  The transformer is 125-0-125 and I am using the 125 sides to put 250VAC into a dioide-bridge rectifier.  I end-up with about 360VDC, which I roughly what I expected from the cap-input filter system.  My heaters are run from a separate 6.3VAC transformer, the center-tap of which is referenced to 1/4 of the B+ voltage.
So, should I ground the center-tap of the 125-0-125 transformer?  Ultimately, I want to float the PSU/signal grounds via a diode-bridge/cap/resistor system to Earth.
I'd appreciate any help,
Thank-you,
Charlie
Occam
Re: how to wire center-tap of a Hammond transformer
« Reply #1 on: 18 Jan 2007, 01:47 am »
No. Assuming you want that 360vdc B+ plate supply, you want the transformer wired to produce 250vac, with those 2 125vac secondaries wired in series, with the center tap left alone.
