0 Members and 1 Guest are viewing this topic. Read 2691 times.
As far as I know Klaus does not use true balance operation in his amps. While there is an XLR receptacle it does not function in a true balanced configuration. I changed from balanced to all RCA. I would call Klaus to discuss.
Quote from: Eugene2 on 13 Jan 2007, 11:22 pmAs far as I know Klaus does not use true balance operation in his amps. While there is an XLR receptacle it does not function in a true balanced configuration. I changed from balanced to all RCA. I would call Klaus to discuss.I turned off the Stratos. Then test whether the ground pin is connected to any of the 2 signal pins. My XLR -RCA converter worked that way. The result is that they are not. Also, each channel has 2 internal fuses. It makes me suspect that it is balanced design. Just want to have Klaus confirmation.I think amp can sound good with balance/unbalanced design. Just want to know the answer which will help me decide the configuration of my system.
Got response from Klaus:Is it real balance XLR interface?"No. All Symphonic Line amps are single ended. It is jumped to the RCA."
