0 Members and 1 Guest are viewing this topic. Read 2276 times.
Distances between listening position and speakers and the walls would not suggest a quarter wave cancellation at that frequency.
Are you sure? The peaks and nulls related to the distance between you and the wall behind you are almost always exactly where they should be. Since you didn't mention the distance from the measuring microphone to the rear wall, I can't confirm or deny your findings.
The 55hz null should be from cancellation occuring with a boundary about 5.25' away from the mic. There was nothing at this distance.
The windowing function can have an effect on the low frequency response and this is why the frequencies at or below 200Hz are not considered to be valid. The effect is unpredictable.
