0 Members and 1 Guest are viewing this topic. Read 7771 times.
Can you comment on your new AC conditioner (the world's smallest), the XDC2 ($299)?
Dusty, do you plan to make a 4 outlet version? I'm interested and wish you the best of luck with the new products!
Hey Dusty, do you also plan to make an European version available with Schuko-outlets?
From time to time my D200's will produce a mechanical hum, so I assume DC is most likely the culprit of this. Other than making the amps run quieter, which really doesn't bother me, can't hear it with the music playing, will the XDC-2 enhance the sonics of the amp?
QuoteFrom time to time my D200's will produce a mechanical hum, so I assume DC is most likely the culprit of this. Other than making the amps run quieter, which really doesn't bother me, can't hear it with the music playing, will the XDC-2 enhance the sonics of the amp?XDC-2 will eliminate the hum and also improve sound quality...It provides high frequency filtering in addition to DC blocking. It's not a necessity if the hum doesn't bother you, but still an inexpensive way to clean-up your AC power.The new D-400 will have this circuit built-in to it's power supply.
QuoteHey Dusty, do you also plan to make an European version available with Schuko-outlets?XDC-2 is designed to work with 240v lines, you just use your country's power cord for the input, and American style cords to the components.We won't be making them with sockets for each 220~240v country because they all use something different.
Just one question; presumably, I can have one output feeding one D200 and the CD player and the other output can feed the 2nd D200 and the VAC-1 which is suplying the DAC?
(BTW...I'm sending you a pre-production prototype today with your cables).
Your device looks good, now how long before the outlet comes in a cryo version? Hmmm, that should have been a standard feature...Cryogenics International? Hi, this is Dusty from Channel Islands. How much for cryoíng 600 pounds of Hubbell outlets? You like to deal in quantity, don't you?
