SP2 Options
0 Members and 1 Guest are viewing this topic. Read 3135 times.
onthefly
SP2 Options
« on: 9 Jan 2007, 02:17 pm »
Does anyone know if the SP2 can be had with the XLR digital input in place of the two opticals?
Phil A
Re: SP2 Options
« Reply #1 on: 9 Jan 2007, 02:25 pm »
I would think so although not positive. My SP 1.7 has that as when I got it my DVD transport at the time had a balanced digital out.  If not, I'm sure you could find an SP 1.7 at worst and upgrade it.  I'll eventually upgrade mine and at this point I don't care whether I have 2 optical or a single XLR digital input.
onthefly
Re: SP2 Options
« Reply #2 on: 9 Jan 2007, 02:28 pm »
I'm about to order a new SP2 and I want to know for sure before signing on the dotted line.  The dealer says yes but I would like to hear perhaps James confirm this.  I reckon he is at Vegas right now.
Thanks for the reply.
MOZ
Re: SP2 Options
« Reply #3 on: 9 Jan 2007, 04:12 pm »
That was possible with the SP1.7 (that's what i did)... so i don't see why it could'nt be possible with the SP2..
My SP1.7 has been upgraded SP2 and still have the digital XLR (but they had a problem making it work with the XLR thing, waiting for a firmware update)...
But only James could tell !
  • The Demo is Everything!
    • http://www.bryston.com
Re: SP2 Options
« Reply #4 on: 10 Jan 2007, 05:20 am »
Hi ONTHEFLY,
We can install an AES EBU instead of the 2 optical inputs but the software has not been written yet so the diplay will say Optical 1 when you assign the AES-EBU to an input.Other than that it works fine.
Yes I am at the Vegas show.
james
onthefly
Re: SP2 Options
« Reply #5 on: 10 Jan 2007, 02:23 pm »
James
Thank you.  Looks as though I am about to order a SP2 Pro!
Phil A
Re: SP2 Options
« Reply #6 on: 10 Jan 2007, 04:24 pm »
[/quote]
Hi ONTHEFLY,
james
[/quote]
James, it is also possible if someone has the SP 1.7 Pro and decides to upgrade down the road to have the XLR replaced by 2 optical inputs?
thanks
Re: SP2 Options
« Reply #7 on: 11 Jan 2007, 05:29 am »
Hi ONTHEFLY,
james
[/quote]
thanks
[/quote]
YES
Levi
Re: SP2 Options
« Reply #8 on: 21 Jan 2007, 02:33 pm »
Hi James,
Does this mean that the SP1.7 or SP2 with AES EBU will be running in fully balanced topology from input to output?
LEvi
Re: SP2 Options
« Reply #9 on: 21 Jan 2007, 04:23 pm »
Hi James,
LEvi
Hi Levi,
No the AES EBU is just the digital interface. Here is a link to a newsletter we did some years back on fully balanced circuits throughout a component.
http://www.bryston.ca/newsletters/31_files/vol3is1.html
james
Levi
Re: SP2 Options
« Reply #10 on: 22 Jan 2007, 02:19 am »
I think I read that article before.     :duh:
I am pretty sure some manufacturers may argue with Bryston's view on fully balanced topology volume 3 issue 1.
Don't get me wrong, my Bryston Preamp and amp noise floor very low!
Thanks James.
onthefly
Re: SP2 Options
« Reply #11 on: 25 Jan 2007, 03:40 pm »
Now you've got me questioning whether it's actually worth specifying the XLR upgrade :scratch:
Decisions, decisions............
Hi James,
LEvi
Hi Levi,
james
