Scrapiron - your mailbox is full
0 Members and 1 Guest are viewing this topic. Read 1792 times.
Canyoneagle
« on: 7 Jan 2007, 11:40 pm »
Hey, Skot - I tried to respond to your inquiry about my Compact Hemp drivers, and the inbox was full.
Just thought you'd want to know!  :D
Anyway, I'm not sure of the version of the driver I have in these cabinets, so perhaps I can get some advice from Louis.
Louis - is there an easy way to tell which version of the Hemptone 8" driver is in my cabinets?
Should I send you a pic, or is it something I can determine?
Warmly
Michael
Louis O
Re: Scrapiron - your mailbox is full
« Reply #1 on: 9 Jan 2007, 12:24 am »
Hi Michael,
All is set with Skot and I have talked about the drivers with him. I will be upgrading them.
Talk to you soon,
Louis
Canyoneagle
« Reply #2 on: 9 Jan 2007, 01:10 am »
Thanks Louis.
Do you feel that the new drivers would be a worthwhile upgrade to my Hemptones?  What are the key differences, and (if you're willing to share the info) how much would we be talking about for the swap?
Would the originals be good for OB experimentation?
Warmly,
Michael
scrapiron
« Reply #3 on: 10 Jan 2007, 02:40 am »
Whoa, I need to check the old mailbox, thanks for the heads up Michael!
Just checked- I had one message (which I just deleted). Weirdness.
Louis- you are the man. Thanks again for taking the time to talk to me. I'm looking forward to replacing the drivers... though not the break in period. :)
-Skot
