HDMI repeater/ active equalizer
0 Members and 1 Guest are viewing this topic. Read 1087 times.
RawB8figure
« on: 7 Jan 2007, 07:43 am »
Hey guys,
First post, but have any of you guys or girls used a HDMI repeater/equalizer.  I have a 25FT run of HDMI to my projector and run it at 720P and it sometimes drop signal (once during a movie). So I talked with the guys I bought the cable from and they suggest me buying this.
http://www.monoprice.com/products/product.asp?c_id=104&cp_id=10419&cs_id=1041907&p_id=2849&seq=1&format=2&style=
Anyone try one of these, do they work?
jqp
Re: HDMI repeater/ active equalizer
« Reply #1 on: 7 Jan 2007, 05:33 pm »
I would hate to buy something without knowing why it is needed - what is the source of the HDMI signal that is dropping?
RawB8figure
« Reply #2 on: 7 Jan 2007, 08:14 pm »
It is from my DVD player. But this device is suppost to stop that from happening over long HDMI cable runs. Just wondering if it actually does, because it is a rather inexpensive piece of equipment. They should just integrate it directly into the cable at that cost
jqp
« Reply #3 on: 7 Jan 2007, 08:35 pm »
It says it is powered by the power line of the HDMI port. I also seems you would have to add a second cable on the other side of the extender, so even more money...
I don't have a projector and I am not sure about the specs for HDMI and cable length, or your DVD player. I would think you should be able to go 25 feet, but maybe not, maybe there is interference? Not sure what the Integrated Circuit 3815 is. This device seems to be a basic signal amplifier and it might work fine for your situation.
I will defer to others who have more direct knowledge...but I am wondering if you could exchange your current cable for a more suitable cable such as the "24 AWG STP". Maybe that is the cable you could use without the extender?
RawB8figure
« Reply #4 on: 7 Jan 2007, 11:27 pm »
The HDMI I am using is 22AWG and full shielded. But I don't think there is any interference.
