Integrety Research Mono-Blocks. Real Nice.
0 Members and 1 Guest are viewing this topic. Read 1004 times.
Rocket_Ronny
    • ScriptureSongs.com
« on: 5 Jan 2007, 05:19 pm »
Had a nice conversation with Kurt Wishman, the designer of the Integrety Research gear, or IRD Audio. Website: http://www.irdaudio.com/
I liked what he had to say about his products, including his pre and mono blocks. He said this is a sideline hobby of his and a labor of love. His amps are super cheap at $269.00 each. He says they are a loss leader for the company, and one would have to spend about 10 times the price to get anything much better. Where he makes his income is with his infrared control systems and the like.
I don't know, my Spidy senses are telling me the "Killer Value Meter" is spiking with this find.  :drool:
Has anyone heard these things?
Rocket_Ronny
TheChairGuy
Re: Integrety Research Mono-Blocks. Real Nice.
« Reply #1 on: 5 Jan 2007, 06:23 pm »
Curt introduced the MB-100's probably 3+ years ago now.
They are chip amps, 100 watts a side, and as is typical IRD, probably built extremely well.
I've not heard them, but I seem to rember good comments made about them at one time or another.
You can find more information on their circle here on Audio Circle at:
http://www.audiocircle.com/index.php?board=33.0
$538 for two, new monoblocks of 100watt SS power is pretty hard to top, I'd say.  That might even be the delivered cost from their North Carolina warehouse.
smccull
« Reply #2 on: 5 Jan 2007, 07:00 pm »
I checked out their site and was very intrigued by their amps and their pres. Regarding the latter, I found this very interesting. Anyone hear of this approach?
<snip>
Why do the Preamplifiers have both a gain and a volume control? Aren't they the same thing?
Preamps vary in signal gain (active gain circuit) from 0dB to about 12dB max. This is because different source-amp combinations can require different amounts of gain to reach their full volume potentials. There are no standard gain specifications.
IRD LLCs allow you to select the right amount of active gain for your exact system combo. By selecting the least amount of gain you need you optimize your systems performance and keep the systems noise at a lower level.
The volume control (passive attenuation device) allows "all of the signal" or only "part of the signal" to pass on through to the amplifier. It has 24 attenuation positions, mostly small high resolution 1.5dB steps. Our volume control's small 1.5dB steps allow for precise and subtle room SPL control over a very wide range, a very desirable feature.
We could have used a high fixed gain (at the expense of increased system noise) and allowed the VC to attenuate the signal to the correct level (at the expense of volume resolution, i.e. lost VC positions) but we do like our low noise, wide range, high volume resolution solution much better.
You may have used gear in the past where the systems volume is up full blast by the VCs 9 o'clock or twelve o'clock position, this is a very good example of too much gain and not enough volume control resolution. We would consider this type of system non-optimized and poorly matched, most likely it would not produce the systems optimum performance.
fredgarvin
« Reply #3 on: 5 Jan 2007, 08:05 pm »
I've been using the Purist pre for some time and have no plans to change. Dead-quiet unit and the variable gain is a very nice feature which I find helpful. I use zero gain most of the time but have found that on certain flat sounding LP's a gain boost ups the 'lively' factor. Also nice if using low efficiency speakers. Two outputs is also handy. I have listened to several other pre's and have really heard nothing that is better overall, tube or SS. I do not want battery power, so have not tried the Dodd, at $3000. This is a killer and only $650 or so.
Rocket_Ronny
« Reply #4 on: 5 Jan 2007, 08:35 pm »
« Last Edit: 5 Jan 2007, 08:56 pm by Rocket_Ronny »
