0 Members and 1 Guest are viewing this topic. Read 2598 times.
Why all the sarcasm and vinegar? I took time to try to be helpful and I get that? have fun.
Josh, I'm sorry if I was sarcastic, but obviously you didn't think a whole lot or perhaps read my requirements. I don't need a new PS; I already have two that work quite well. I just want to put better-sounding caps in it. BTW this PS feeds only the output stage; the frontend and bias supplies are completely separate after the power transformer, and the frontend supply is tube-regulated.
I believe (but don't know) that 2 caps in series sound twice as bad as a single one, so my goal is NOT to use caps in series in the 2nd pole of this PS.
Maybe the single, perhaps-slightly-lower-quality auricap will sound better than 2 perhaps-higher-quality caps in series. If the Mundorf Supreme Silver/Oil were more reliable under Voltages approaching its 1200VDC rating, that's what I'd use, as they sound quite good...but they're not. I guess I'd try the auricap or the Rel. RT first, but that'll happen only after the new PSs have at least a few-dozen hours on them. Again, I've compared the sounds of these 2 mono amps (in mono, of course) with the different 2nd-pole caps; the amp with the 'propylenes sounds cleaner, quicker, AND smoother, a combination that's not always achieved..* These caps in quote marks are actually 2 caps in series of double the value and half the Voltage.
