0 Members and 1 Guest are viewing this topic. Read 9141 times.
- Wayne's (Boulder) analog modded Squeezebox SB3 $700 (total roughly)- Vinnie's (RWA) Sig 30 $1400- GR Research AV/3 kit - under $900 - way under actually - there are a bunch of speaker kit options that would stay under $900 - used speakers are also a good route.This would potentially be a very fine sounding rig.If the computer contributes too much noise, there are options for dealing with it.
I want to stress that these are my opinions only. They are based on 30 years as an audiophile and 40 years as a professional musician but there are many experienced people on these forums. Some probably would agree with my opinions and some wouldn't.
Just to expand on the recommendations I gave you on the Stereophile forum,I don't think the modded SB would be the way to go. You can buy a stock power supply for the SB and get so much bang for the buck that I don't think you will hear any significant improvement from further modding. I didn't in my 40,000.00 system. The stock Elpac power supply is only 40.00. I later bought a modded Elpac and heard NO difference.IMHO I think you will get much better sound spending more on your speakers.There are many audiophiles that think speakers should get the majority of the budget and I agree. Of course, there are others who disagree.When you want to upgrade your source you will get much more improvement from the addition of a DAC such as the LAvryDAC10 or the Benchmark. These are well established pro audio companies that do far more R&D than an independent modder can do.A stock SB 300.00 with a Lavry @900.00 brings you to the level of a 2,000.00 Transporter for 1,200.00 IMHO the various modded SB's that I have extensively auditioned and reviewed out there don't come up to that level of sound quality. You will also not have the problem of voided warranties.In any event if you put more into your speakers and amp you can always decide later to buy a DAC for your SB or modify the SB, but at least you wont have cheated yourself on the speakers or amp.I want to stress that these are my opinions only. They are based on 30 years as an audiophile and 40 years as a professional musician but there are many experienced people on these forums. Some probably would agree with my opinions and some wouldn't.Above all, try to listen to anything before you buy. Most manufacturers offer a 30 day trial. I believe Slimevices does on the Squeezebox . Most online retailers offer this.If you can't get a trial then it may be better to not buy that product.Only you can please your ears, we can only give you advice which may or may not be good for you.Have fun, oh, and I still have that bankruptcy attorney's name , you might need it if you catch this audiophile bug
I appreciate everyone's comments, I've certainly learned that I have more options than I originally thought. The Squeezebox 3 appears to be one of the most recommended devices on here...is this truly necessary if my computer is in the same room (close proximity) to my stereos? I also understand that the SB can also be connected by direct wire (not wireless) - if so, what is the advantage/disadvantage of having a SB versus a nice DAC?jr314
