Budget. .$1500-$2000
0 Members and 1 Guest are viewing this topic. Read 1860 times.
pjchappy
« on: 4 Jan 2007, 04:48 pm »
A friend of mine told me he bought some speakers. . .I THINK he said they were Prestige, or something like that.  Never heard of them.  He said they were $1500.  Knowing that I'm into this hobby, he now wants a reciever, or something, to go w/ them.  I suggested the modded Squeezbox route and an amp.  Not sure he wants to go the PC route.
SOOO, any suggestions for a receiver for him for the above budget?  He wants the convenience of a receiver.  Probably a multi-channel one for future expansion?  Not totally sure.  Also, any suggestions for an integrated or amp and pre for the same budget (2 channel). . .I will suggest he goes this route.
p
pjchappy
Re: Budget. .$1500-$2000
« Reply #1 on: 4 Jan 2007, 07:58 pm »
OK, I really should have had more information b/4 I started this thread.  Anyways, these are his speakers: http://www.definitivetech.com/loudspeakers/procinema/procinema_1000.html
So, any suggestions for a receiver for up to $1500?  Thanks!
p
woodsyi
« Reply #2 on: 4 Jan 2007, 09:16 pm »
This one is in your neighborhood.  http://cls.audiogon.com/cgi-bin/cls.pl?miscrcvr&1172971300  I don't have it and I don't have Def Tech speakers, but Arcam has good reputation.  I would think it would do his speakers justice.
pjchappy
« Reply #3 on: 4 Jan 2007, 09:27 pm »
Doubt he'd be interested in used equipment.  Thanks, though!
p
WEEZ
« Reply #4 on: 4 Jan 2007, 09:49 pm »
Have him check out the NAD receivers. Usually available at less than full list price...try www.audiophileliquidator.com
Marbles
« Reply #5 on: 4 Jan 2007, 09:52 pm »
This would be my pick...he can save some money too...
http://www.outlawaudio.com/products/rr2150.html
Carlman
« Reply #6 on: 4 Jan 2007, 09:55 pm »
Denon makes great stuff...  I found this write up about a recevier and DVD/CD player... http://www.hometheatermag.com/receivers/903denon/
pacifico
« Reply #7 on: 4 Jan 2007, 10:02 pm »
The NAD stuff is reasonable although my C372 can be a bit dark; although on a good night I've heard the speakers dissappear in the room. This was done with my paradigms and my response audios. gotta tell you though the response audios are really starting to surprise me woth their detail and 3D imaging abilities. Bill promised me this would happen and sure enough I am right around the break in point he mentioned where this would happen. Right now I am torn between a transcendant pre amp kit or a sig 30 for my two channel rig. I'll probrably wind up with both at some point b/c the NAD will be along time keeper. I think with an affordable preamp it's really worth the money. Got mine from yawaonline.
In retrospect though not sure if I would buy NAD again but then again I am on the upgradeitis bandwagon like many here. Your friend should at least go listen to one and bring the monitors. YMMV
pjchappy
« Reply #8 on: 4 Jan 2007, 10:16 pm »
He's not in this hobby. . and I know he wouldn't want to check out a bunch of stuff to see what matches his speakers.  So, I'm just looking for something that will suit his speakers well enough.  I've always heard good things about Outlaw. . but Marbles, you showed me a stereo receiver.  Are their multi-channels just as good?
p
Marbles
« Reply #9 on: 4 Jan 2007, 10:24 pm »
p
I don't think their HT stuff is up to this quality...FWIW, even though it's only 2 channel, it does have a subwoofer out.  It wasn't clear (to me) in your first post if he needed an HT receiver or if a 2 channel would work.  I don't have an HT receiver recomendation (new) in his price range.
pjchappy
« Reply #10 on: 4 Jan 2007, 10:29 pm »
Yeah, sorry. . .I definitely didn't make that clear.
PhilNYC
« Reply #11 on: 4 Jan 2007, 10:42 pm »
In this price range for AV receivers, I like offerings from Arcam and Rotel...
ohenry
« Reply #12 on: 4 Jan 2007, 11:02 pm »
Don't miss the Cambridge Audio 640R for $1300...
http://www.audioadvisor.com/prodinfo.asp?number=CA640R
pjchappy
« Reply #13 on: 4 Jan 2007, 11:31 pm »
Anyone have experience w/ the speakers he has?  I'm just wondering if anything will make a dramatic difference. . .especially w/ someone who may not care so much?
boead
« Reply #14 on: 5 Jan 2007, 02:09 am »
I know those speakers, a friend has them. He paid around $900 for the system from a local HiFi shop, it was a good price so he says.
I set him up with everything else. A Denon AVR 380x and a DVD-2900, for a Panasonic Tau 36” HDTV CRT over a year ago.
The speakers are disappointing, not particularly musical but good for Movies and TV and are tiny and easy to place and hang. Sub sucks!
I’ve had a few Denon AV receivers and I know a number with them too, they are sort of sterile and lack luster. Nothing particularly good about them, but noting particularly bad either. They definitely lack body and that nice robust mids and bass. Something the Definitive speakers desperately need so I’d say the Denon would be a poor match.
I got rid of my last Denon AVR 280x something that I really didn’t’ like. I had a few speakers to choose from for HT. I used it with a nice pair of early 80’s Energy Pro 22’s. I also had an NHT sub/sat system and some KRK RoKits. I replaced with a Pioneer VSX-D811S receiver. It has more body, more bass and a softer sound that is more musical. I also have a Kyocera 2-channel receiver from the early 80’s that puts them to shame. I also have an early 70’s Sansui 2-channel Integrated that also puts them to shame but anyhow.
I’d say the Arcam Receivers are of the best for the money and buying one a couple of years old is wise. You can get the units for a lot cheaper then new. Audio gear are likes cars, as soon as you open the box or pull out of the lot the value depreciates tremendously.
Either way, I’d look for a richer, bass heavier amp to make those speakers sound half way decent for music.
Just my 2 cents.
« Last Edit: 5 Jan 2007, 01:36 pm by boead »
