Update to Date SP 1.7 IR Remote Codes
0 Members and 1 Guest are viewing this topic. Read 1468 times.
BMU (Bryston Maggie User)
« on: 1 Jan 2007, 05:26 am »
Hi all
I'm a new member here and recently purchased a used SP 1.7 (upgraded from a SP 1).  Incredible sonics c/w my previous NAD home theatre receiver serving as a multi-channel pre-amp.
I'm slowly reading the material on this most useful forum and came across...
To Enable or disable the backlight in the remote:
You can try this settings.  This is straight from the manual.  Default was disabled.
Press CODE button for 5 seconds
LED will flash red, then release button
Type in 3 digit code 792=MODE /SAVE /DTS
LED will flash again to confirm
Levi
My Sp 1.7 manual does not have a list of codes.  The one posted on the Bryston website is Revision 600-39 (August 12, 2002) which I suspect is not the most recent one.
James can you update the website documentation or someone make a newer list of codes available.
jethro
Re: Update to Date SP 1.7 IR Remote Codes
« Reply #1 on: 13 Feb 2007, 02:29 am »
James:
Any updates ?
Thanks.
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #2 on: 13 Feb 2007, 03:51 pm »
James:
Any updates ?
Thanks.
Hi Jethro,
Mike Picket at Bryston is working on it.
james
