The "Formula One"
0 Members and 1 Guest are viewing this topic. Read 7315 times.
Marbles
The "Formula One"
« on: 31 Dec 2006, 07:32 pm »
Steve, since you will be making this one from scratch, is there any chance that it will be less expensive then some of your current modified gear?
Can you give us any info on it yet?
audioengr
Re: The "Formula One"
« Reply #1 on: 1 Jan 2007, 10:28 pm »
Here are the features:
Inputs - all digital:
S/PDIF
AES/EBU
USB
I2S
Outputs:
RCA's Single-ended - volume controlled
XLR's Balanced - volume controlled
Possible Sub outputs - volume controlled
headphone output - volume controlled
It will have remote-controlled input select, volume and muting.
It will be NOS, using the AD1853 D/A chip
It will be DC-coupled
Possible balanced from the D/A chips to the XLR's
Pace-Car inside - lowers jitter on all inputs
Switch to select fast and slow digital filter roll-off
Solid aluminum machined chassis, Sorbothane feet
Furutech IEC
Superclock4's clocking all data to the D/A chip(s)
LI battery power on critical circuits (mostly analog) - may be optional
May have MCLOCK output to drive and synchronize a transport clock (11.2896MHz, 24.576MHz or 49.158MHz), not a word-clock.
MSRP - probably $7K-10K
« Last Edit: 28 Feb 2007, 11:50 pm by audioengr »
OrJazzM
« Reply #2 on: 27 Feb 2007, 10:45 pm »
Hi Steve, being that this DAC is SS can it be battery powered?
audioengr
« Reply #3 on: 28 Feb 2007, 11:47 pm »
Yes, I had planned on LI batteries, but it may be available in AC only as well.
Steve N.
PLMONROE
« Reply #4 on: 1 Mar 2007, 01:00 am »
Hurry up, I want one.  aa aa aa aa
Imperial
  • Love keeps us in the air, when we ought to fall.
« Reply #5 on: 11 Mar 2007, 08:45 am »
Is "the formula one" the same as the new "Spolier tube dac" ?
Imperial
audioengr
« Reply #6 on: 11 Mar 2007, 06:55 pm »
Imperial
No, the Formula One is being designed still.  It is a SS DAC.
Steve N.
Audiophiliac
« Reply #7 on: 1 Jun 2007, 02:57 am »
Any latest on the F1? I decided against the M192 at this time....in lieu of buying a new vehicle. From the sounds of it, this DAC will be the last DAC I will ever need to buy...a great investment! :)
audioengr
« Reply #8 on: 2 Jun 2007, 07:37 pm »
I am toying with making it the form factor of the Benchmark/Lavry and more in the $2000 range than $8K.  Would like to have remote control though.
Steve N.
Audiophiliac
« Reply #9 on: 2 Jun 2007, 10:02 pm »
Steve N.
Awesome!! Seriously...if you can provide the above listed features, and a remote control, AND price it around $2-3k, I will definitely be one of the first in line! Keep us posted.
OrJazzM
« Reply #10 on: 2 Jun 2007, 10:04 pm »
Steve N.
That's something I would be very much interested in!
bigamp
« Reply #11 on: 2 Jun 2007, 10:41 pm »
Me too.   :)
OrJazzM
« Reply #12 on: 14 Jun 2007, 01:08 am »
Hi Steve, can you provide a little more info on the features of the new dac you're working on.  Also you said it would be in the benchmark/lavry form factor, so I'm assuming it's going to be comparable to those units sound wise.  Thanks for your time Steve.
Audiophiliac
« Reply #13 on: 14 Jun 2007, 03:23 am »
OrJazzM,
Here are the specs listed on the first page of this thread....I am sure some have changed along the way, but should give you some idea of what Steve is trying to accomplish.
The form factor likely only refers to the physical size of the unit....I doubt many of the parts inside will be exactly the same.
S/PDIF
AES/EBU
USB
I2S
Outputs:
Furutech IEC
OrJazzM
« Reply #14 on: 14 Jun 2007, 03:44 am »
OrJazzM,
S/PDIF
AES/EBU
USB
I2S
Outputs:
Furutech IEC
Thanks, I think.. now I just want one even more badly  :evil:  :D
audioengr
« Reply #15 on: 14 Jun 2007, 04:49 am »
If it is reconfigured for the $1.5-2K range, the Formula One will probably not include a Pace-Car reclocker or LI battery power and it will not have a chassis milled from a block of aluminum like the original Formula One was envisioned to have.  However, it will include most of the listed features and of course have the sound quality that our DAC's are famous for.
Steve N.
Audiophiliac
« Reply #16 on: 14 Jun 2007, 05:31 am »
Thanks for the updates Steve. I can live without the milled Al chassis....and I can live without the Li battery power....and I can probably even live without the pacecar (this would be able to be used in addition to the DAC, right?)...my biggest "wants" are a top notch volume control, remote control, USB input, balanced outputs, and a bonus would be subwoofer outputs (both single ended and balanced...or at least the option to run both single and balanced at the same time with no time delay...balanced to amp, single ended to sub...).
Other than that, whatever else you can squeeze in is alright with me. :)
Waiting patiently.  :drool:
OrJazzM
« Reply #17 on: 14 Jun 2007, 03:06 pm »
Steve, would the dac atleast be able to utilize one of your BPS packs?
audioengr
« Reply #18 on: 14 Jun 2007, 07:42 pm »
If that's all you want, it will have all of that I believe.
Steve N.
audioengr
« Reply #19 on: 14 Jun 2007, 07:44 pm »
Good question.  I suppose I could power the USB interface internally or externally, selected by a switch, like I do on the Spoiler.  This would be particularly useful for operation without Pace-Car.  Even the Pace-Car sounds a bit better with the battery though.  Powering the analog section from Battery is much more complicated.  Requires much higher voltage and +/-.
Steve N.
