SST inputs on back
0 Members and 1 Guest are viewing this topic. Read 1351 times.
mr_bill
SST inputs on back
« on: 31 Dec 2006, 05:05 pm »
James,
Can the RCA and Balanced inputs on the back of the SST amps be simultaneously or both plugged with two different sources and then toggled on the back with the selector switch.  In other words can a home theater receiver be plugged into the rca's and a preamp be plugged in to the xlr's and then via the selector switch on the back of the SST, you can select which sources (preamp or HT receiver), you want to use?
Bill
ec
Re: SST inputs on back
« Reply #1 on: 31 Dec 2006, 05:24 pm »
Yes, a few members are doing this currently.  However wouldn't it be easier to run the the HT receiver out to the preamp to simplify the wiring.  You will have to rebalance the output appropriately one time though.
