Connecting external AMP to B100sst
0 Members and 1 Guest are viewing this topic. Read 1611 times.
jgiord
« on: 31 Dec 2006, 01:29 am »
Can I connect an external power amp to my B100-sst integrated amp?  If so, would I connect to the Power AMP In and set the Separate/connected switch to separate.  Thanks.
  • The Demo is Everything!
    • http://www.bryston.com
Re: Connecting external AMP to B100sst
« Reply #1 on: 31 Dec 2006, 01:30 pm »
Hi,
Use the PRE OUT and set the switch to Separate.
james
jgiord
« Reply #2 on: 31 Dec 2006, 02:10 pm »
Unfortunately the pre-out is being used to connect a subwoofer.  Can I use a y-cable to connect to both subwoofer and power amp simultaneously.  Thanks.
« Reply #3 on: 31 Dec 2006, 03:26 pm »
Yes a Y cable should be OK - only issue may be a ground loop depending on the other amplifier- what amp are you using?
james
jgiord
« Reply #4 on: 31 Dec 2006, 03:42 pm »
Plan to purchase a stereo amp off audiogon (not sure which one yet).  Need more power as I'm clipping the b100sst.  Any type of amp I need to avoid to prevent the ground loop?
« Reply #5 on: 31 Dec 2006, 03:58 pm »
Well a Bryston would not be an issue of course but other amps will just have to be a trial and error approach.
james
jgiord
« Reply #6 on: 31 Dec 2006, 04:22 pm »
Thanks...haven't ruled out a Bryston, depends on what's available.  Looking for at least an AMP of comparable quality.
