0 Members and 1 Guest are viewing this topic. Read 7828 times.
A couple questions though on Live. Do you need to get another IP for Live? I'd rather not have to pay $5 a month for yet another IP.
And does the kit come with a network cable? I'll need a 25' cable to get from my router to the 'box. And if it doesn't come with one I'll have to start asking around for one.
QuoteA couple questions though on Live. Do you need to get another IP for Live? I'd rather not have to pay $5 a month for yet another IP.No, you do not need a static IP address. My box goes through 2 switches before it gets to my router, which has NAT running & a dynamic address.QuoteAnd does the kit come with a network cable? I'll need a 25' cable to get from my router to the 'box. And if it doesn't come with one I'll have to start asking around for one.No ethernet cable included. If you find an independent PC shop you can probably get a long cable made for much less than it will cost you from a Best Buy or Circuit City. A 25' ethernet cable is about $2 worth of material.
The LFE is frightening to put it mildly.
Hmm...that may be doable. I'm not as good as I wish I was, but Mech Assault rocks supremely on Live. Gimme a PM if you end up getting it, Brian.
