Hi Felipe,
Ah, we've hooked up immediately!
You mentioned in your email that when you turned off the mains, without the trafos the hum went away, and that clearly it's coming through the supply somehow.
The usual way to fix this is to wire in a power line conditioner, but since this problem appears to be unique there may be something more to it......
Is it still present if you short the signal hot to signal cold at the pcb?
The other possibility could be hum induction through the trafos, or indeed power wiring profiles on the AC side.
The LF normally has even lower noise than the AKSA, so while I try to keep an open mind I don't believe it's the modules.
Hope this helps, keep pluggin' away, we will get there!
Happy New Year!
Hugh
