Speaker fuse question
0 Members and 1 Guest are viewing this topic. Read 17651 times.
budyog
  • I don't listen to audio, I listen to music.
Re: Speaker fuse question
« Reply #40 on: 29 Dec 2006, 09:34 pm »
Geeze, it was like pulling teeth! :green: But we finally got somewhere.  :scratch:
Again, just to clarify, I was not asking about the fuse in regards to the protection or to play my system louder but I am all for protection and being able to play it loud. I was asking because of all the wire questions, and yes, I have heavy 10 gauge wire from my 350 to my speakers of good quality and good sounding ICs and 2-AC power tweak units, and yes, I did put a 12 gauge power cord on my 350. Did I hear a difference? I can't answer that because when I did it, something came up and there was a long gap between listening, but I left it and I feel better knowing that there is 12 gauge wire all the way from my breaker box to my 350. I do like what all the tweaks have done to my sound. But after I blew a couple fuses, it made me just wonder about all that coming down to that little thin wire in the 1" fuse?
A lot of information is going through that little wire. I can tell you this, The sound does degrade just before it blows. Not surprising. I guess I will start off by trying some better fuses down the road and let you know. Kind of a sticky wicket! :scratch:
Thanks for coming back Frank and to those who can read and those who supllied other good information and the web links.
Happy New Year :beer: :guitar: :drums: :violin: :banana piano: :hyper:
shep
« Reply #41 on: 29 Dec 2006, 10:56 pm »
Just assuming that there might be an audible difference in types of fuses, it stands to reason that those nasty clips holding the fuses might also have a part to play. I seem to recall a friend who was into this sort of thing used to replace them with a wire tag and solder the fuses at each end. By the by, those Maggies I mentioned are now 22 years old and the last time I asked they were still going strong, minus fuses. I know accidents happen but if you have decent equipment and are carefull it's not that easy to blow a fuse.
Listens2tubes
« Reply #42 on: 30 Dec 2006, 01:30 am »
:roll: OK here I go.....A couple months back I attended an audio club meeting where one of the clubs members held a fuse shootout, which the German fuses took the nod, once chosen they were bettered with the addition of silver contact grease.  :oops: Not to hijack the proceedings but my parents chandelier no longer strobes once warm since silver treating the bulb bases.  :duh: Here we go!
Listens2tubes
« Reply #43 on: 30 Dec 2006, 01:37 am »
Yes a Happy and Healthy New Year  :beer: :guitar: :drums: :violin: :banana piano: :dance: Just had to tweak it!
avahifi
    • http://www.avahifi.com
« Reply #44 on: 30 Dec 2006, 11:54 am »
You can, of course, simply buy "pigtail" fuses.  These have wires on each end for hard soldering instead of clipping them into a holder. Of course then you have to disassemble and unsolder and resolder to replace fuses, not a lot of fun.
Frank
shep
« Reply #45 on: 31 Dec 2006, 04:14 pm »
NO mockery Please! Rather than spend 50$ on a pair of fuses, I went the irrevocable route and got rid of them altogether: bi-passed with tiny pieces of silver solid core I had from another DIY project. So...I don't want to encourage anyone to go this way, especially if you have expensive gear. And yes, there is a noticable lowering of the noise floor. Is it worth it? Probably not, against the risk entailed, but in 35 years i've never had a fuse blow (fingers crossed against Muphey's Law).
CE2
« Reply #46 on: 31 Dec 2006, 07:05 pm »
 :nono: :nono: :nono: :nono: :nono: :nono: :duh: OK Homer Simpson Jr., do you also like work at the power plant?....You probably had oxidized fittings, and all you had to do it clean em, since you say you NOTICED a lowered noise floor.  We don't need no stinkin' fuses.
avahifi
« Reply #47 on: 31 Dec 2006, 08:09 pm »
Of course, removing the fuses also removes the warranty.    :o
Frank
shep
« Reply #48 on: 31 Dec 2006, 09:00 pm »
Actually they were not oxidized and this cdp has no warrenty anyway since it was a 2nd hand. I guess this is not a welcome topic so I will bow out and say no more. To each his own thing. Please notice that I did not recommend this.
boead
« Reply #49 on: 31 Dec 2006, 10:06 pm »
its a tough crowd.  :peek:
shep
« Reply #50 on: 31 Dec 2006, 10:13 pm »
yup!...gotta do what a man's gotta do... happy (almost here 11:15) new year
