VMPS will show and demo the RM v60 at THE Show RM1805 during CES
0 Members and 1 Guest are viewing this topic. Read 3256 times.
John Casler
Hope to see you all in Las Vegas during CES.
We will be in the St Tropez RM 1805 and the RM v60's will be there, driven by the AtmaSphere M2 200W OTL monoblocks.
Bring your best demo cuts :green:
Brian Cheney
    • http://www.vmpsaudio.com
Correction: AtmaSphere MA2 OTL monoblocks.
Hugh
    • Angel City Audio
John & Brian,
I'm looking forward to listen to those gorgeous ladies. :drool:
Hugh
Brian Cheney
So far I'm the only person to hear the V60 playing music, and it's an amazing sound.
The V60 is a constant directivity planar with 180 degree dispersion horizontally due to its diffraction slot loading. The long, sharply folded wings also eliminate front edge diffraction and any cancellations from the Dipole Effect on the back wave.
But... it is also a reverse horn, controlling the directivity of rear radiation above 280 Hz.  I am beginning to understand horn aficienados.
The combination of the two sounds, wide dispersion direct planar and horn-loaded rears, gives the system a stentorian authority not previously heard from any flat panel speaker in my experience. Plus I have added a twist.
More later.
